一种基于解释的知识库综合
消耗积分:3 | 格式:rar | 大小:215 | 2009-05-07
久醉不醒
分享资料个
从知识库的解释出发,对概念和概念间关系的解释进行了分析,定义了知识库系统的最小概念集合,设计了生成最小概念集合的方法,提出了基于解释的知识库综合算法,讨论了该算法在有限域上的可计算性。Information integration is a valuable research area, which is widely used in distributed databases, cooperative information systems and data warehouses. Based on the interpretation of knowledge bases, interpretations of concepts and the relation of these concepts are analyzed in detail, and the minimal concept set of knowledge bases is defined. Then a method of building minimal concept set is given, and an algorithm of interpretation-based integration of knowledge bases is devised. Finally, complexity of the algorithm in finite domain is discussed.
评论(0)
发评论
下载排行榜
