78M6631固件说明用户指南
消耗积分:0 | 格式:pdf | 大小:529 KB | 2011-12-08
分享资料个
This document describes the 78M6631 firmware (6631_3PH_6S_URT_B21), which can be used with the Teridian™ 78M6631 energy measurement IC. This firmware provides measurements for a 3-phase system along with simple methods for calibration, configuration, and access to metrology data. This document contains the following sections:
• Functional Description: Signal Processing Flow, Functions, Calibration, and Operations
• Configuration and Control: Configurability and Settings
• Communications: Communication Interfaces and Protocols Description
The calculations are done on each of the phases individually and the aggregate measurements are also available as follows:
评论(0)
发评论
下载排行榜
