In a recent discussion with a system designer, the requirementfor his power supply was to regulate 1.5Vand deliver up to 40A of current to a load that consistedof four FPGAs. This is up to 60W of power that must bedelivered in a small area with the lowest height profi lepossible to allow a steady fl ow of air for cooling. Thepower supply had to be surface mountable and operateat high enough effi ciency to minimize heat dissipation.He also demanded the simplest possible solution so histime could be dedicated to the more complex tasks. Asidefrom precise electrical performance, this solution had toremovethe heat generated during DC to DC conversionquickly so that the circuit and the ICs in the vicinity do notoverheat. Such a solution requires an innovative designto meet these criteria:
