DN495,pdf英文资料
消耗积分:0 | 格式:pdf | 大小:94 KB | 2012-01-11
分享资料个
A circuit breaker protects sensitive load circuits fromexcessive current flow by opening the power supply whenthe current reaches a predetermined level. The simplestcircuit breaker is a fuse, but blown fuses require physicalreplacement. An electronic circuit breaker provides thesame measure of circuit protection as a fuse without thesingle-use problem. Nevertheless, an electronic circuitbreaker with a fixed trip current threshold, while effectivefor protection, can become a nuisance if tripped by shortduration current transients—even if the circuit breakerself-resets.
评论(0)
发评论
下载排行榜
