提出了一种基于电容器充放电原理的双扩展内插法,研究了双扩展测时内插器的工作原理和误差分析。双扩展内插法与单扩展内插法相比,能大大提高测时分辨力,并显著减少其内插时间,有效地解决了单扩展内插法中高测时分辨力和快测量速率之间的矛盾。This paper proposed a double stretch interpolation method based on the charge and discharge principles of the capacitors, and studied the working principles of the double stretch time measurement interpolator and its error analysis. The double stretch interpolation method is able to greatly increase the time measurement resolution and reduce the interpolation time comparing with the single stretch interpolation technique. Therefore, the conflict between the high time measurement resolution and rapid measurement speed of the single stretch interpolation method is solved efficiently.
