CD4503.pdf
消耗积分:5 | 格式:rar | 大小:122 | 2008-04-02
分享资料个
The CD4503BC is a hex non-inverting 3-STATE buffer with
high output current sink and source capability. 3-STATE
outputs make it useful in bus-oriented applications. Two
separate disable inputs are provided. Buffers 1 through 4
are controlled by the disable 4 input. Buffers 5 and 6 are
controlled by the disable 2 input. A high level on either disable
input will cause those gates on its control line to go
into a high impedance state.
Features
 Wide supply voltage range: 3.0 VDC to 18 VDC
 3-STATE outputs
 Symmetrical turn on/turn off delays
 Symmetrical output rise and fall times
 Pin-for-pin replacement for MM80C97 and MC14503
评论(0)
发评论
下载排行榜
