提高在噪声环境下的磁卡读写器(MCR)系统
消耗积分:0 | 格式:pdf | 大小:854 KB | 2012-07-27
分享资料个
Abstract: Most magnetic read head data sheets do not fully specify the frequency-dependent components andare often vague when specifying other key parameters. In some cases, the specifications of two very similarheads from two different manufacturers might be quite different in terms of parameters specified and omitted.The limitations in the data sheets make designing an optimum card reading system unnecessarily difficult andtime consuming. This document outlines a strategy to overcome the above shortcomings and offers guidelinesto overcome the noise issues.
评论(0)
发评论
下载排行榜
