nonvolatile, electrically block-erasable (flash), programmable,read-only memory containing 16,777,216 bits organized as 1,048,576 words (16 bits). The MicronR MT28F160A3 shares the same ballout and is functionally similar to the IntelR GT28F160B3. However,Micron’s device has the advantage of a standby current of less than 10UA. The following design considerations should also be noted when replacing Intel’s device with Micron’s MT28F160A3.
