In Switch Mode Power Supplies (SMPS) a transformer provides isolation between the primary source and the secondary load(s). If the SMPS controller is located on the primary side of the transformer, the feedback voltage from the secondary is fed back to the primary side through another isolation barrier, usually an opto coupler.
