LOW OUTPUT IMPEDANCE AT HIGH FREQUENCY FOR DRIVING DYNAMIC LOADS SUCH AS HIGH-SPEED A/D CONVERTERS
IMPROVED NOISE FILTERING
BETTER ACCURACY BY ELIMINATING CAPACITOR LEAKAGE ERRORS
DRIVES LARGE CAPACITIVE LOADS
The Burr-Brown REF102 is a buried-zener-based precision
10.0V reference. It has better stability and about five times
lower output noise than band-gap-based voltage references
such as the PMI REF-10. Still, its output noise is about
600mVp-p at a noise bandwidth of 1MHz (the output noise
of the PMI REF-10 is about 3,000mVp-p at 1MHz).
