实时数据库系统是电力系统支撑平台的重要组成部分。调度中心所有的数据都存储于
数据库中。CORBA 提供了网络环境下的基于面向对象的开发模型,对外提供统一的、与平台无关的接口。每个应用软件都可以变成为一个组件。本文探讨了基于CORBA 组件模型体系的电力调度实时数据库管理系统。
关键词:CORBA,电力系统,数据库,自动化,管理系统
A Real Time System of Electric Power Database Based on CORBA Module Model Wen Yu-Jiang Yang Zhan-Ju Zhao Li-Mei Abstract: The real time database system is an important part of the electric power system. All the data of the attemper center are stored in the database. CORBA provides the OOD model under the network environment and provides uniform and platform-unrelated interfaces. Every application software can be seen as a module. This paper analyzes a real time system of electric power database based on CORBA module model.
Key words: CORBA; electric power system; database; automatization; management system
