| 制造商 | Toshiba | |
| 产品种类 | 晶体管输出光电耦合器 | |
| 配置 | 1 Channel | |
| 最大正向二极管电压 | 1.3 V | |
| 最大反向二极管电压 | 5 V | |
| 最大输入二极管电流 | 10 mA | |
| 最大功率耗散 | 250 mW | |
| 最大工作温度 | + 110 C | |
| 最小工作温度 | - 55 C | |
| 封装 | SOP-4 | |
| 包装 | Reel | |
| 绝缘电压 | 5000 Vrms | |
| 最小正向二极管电压 | 1 V | |
| 输出设备 | Phototransistor | |
| 描述 | 晶体管输出光电耦合器 4DIP HIGH ISO VOLT COUPLER |
Office Equipment Household Appliances Solid State Relays Switching Power Supplies Various Controllers Signal Transmission Between Different Voltage Circuits The TOSHIBA TLP781 consists of a silicone photo−transistor optically coupled to a gallium arsenide infrared emitting diode in a four lead plastic DIP (DIP4) with having high isolation voltage (AC: 5kVRMS (min))。 • TLP781 : 7.62mm pitch type DIP4 • TLP781F : 10.16mm pitch type DIP4 • Collector-emitter voltage: 80V (min.) • Current transfer ratio: 50% (min.) Rank GB: 100% (min.) • Isolation voltage: 5000Vrms (min.) • UL recognized: UL1577, file No. E67349 • BSI approved: BS EN60065:2002 Approved no.8961 BS EN60950-1:2006 Approved no.8962 • SEMKO approved:EN60065:2002 Approved no.800514 EN60950-1:2001, EN60335-1:2002 Approved no.800517 • Option(D4)type VDE approved : DIN EN60747-5-2 Certificate No. 40021173 (Note): When an EN60747-5-2 approved type is needed, Please designate “Option (D4)”
