It is quite typical to monitor the current through a component or a voltage on a node to regulate an input. Some applications may find it more useful, however, to monitor the power through a transistor. One such occasion would be in charging a battery. When the voltage is low, the designer may want more current charging, but as the voltage increases, the current could decrease, ultimately saving charging time and power.
