HI3306的评估板的使用
消耗积分:2 | 格式:rar | 大小:212 | 2009-06-10
分享资料个
The HI3306 is a 6-bit analog-to-digital converter that is
capable of 15MSPS (Million Samples Per Second). For a
complete technical discussion of the architecture and timing
of the converter, please refer to the HI3306 datasheet,
available in the Data Acquisition Products Data Book or you
can find it on the world wide web at
The HI3306 evaluation board includes a number of features
which allow easy use in the lab while providing added
versatility. The board includes an HA5033 unity gain buffer
amplifier to be used as an input driver. It can be removed
from the signal path or even from the board if not needed. A
prototyping area is provided on the board for the addition of
circuitry such as a voltage reference or alternate input driver.
All input/output functions of the HI3306 are accessible either
through a 50 pin edge connect or BNC connectors.
评论(0)
发评论
下载排行榜
