多处理机并行计算自动测控系统
消耗积分:3 | 格式:rar | 大小:111 | 2009-06-13
分享资料个
介绍了多处理机系统的并行计算,在此基础上,给出了采用十刻度策略解决任务排序,
采用满射策略解决任务映射的算法。最后,给出了一个自动测控系统示例,该系统不仅可以使多台处理机同时进行多种不同仪器仪表、设备的测控工作,而且处理机间的通信成本较低,加快了被测对象的测试速度,节省了测试时间。
关键词:多处理机;并行计算;自动测控系统
Abstract:A parallel-calculation model of multiprocessor is introduced in this paper and an
algorithm is proposed which can be used to solve the problem of task-arranging by the strategy of  decimal scale strategy and full-mapping. Finally, give a example of auto-test and control system. This system not only could auto-test and control multi-different apparatus and instrument or equipment at one time, but also reduced the cost of communications between processors, and increased the speed of testing, saved time.
Key words:multiprocessor,parallel-calculation,auto-test and control system
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
