直流绝缘检测的研究与应用
消耗积分:10 | 格式:rar | 大小:136 | 2009-06-16
分享资料个
本文利用不平衡电桥法给出了一个较为精确的,用于电网直流系统计算正负母线绝缘值都出现降低的情况下的正、负绝缘电阻的公式。同时提出了一种主—从式的绝缘监测小系统的设计方案。即用一个绝缘主模块来测量主回路的绝缘电阻,而用专门的支路模块来判断出现绝缘降低的那条支路,并且在实际应用中取得了很好的效果。
关键词:不平衡电桥;主—从式; 绝缘监测。
Abstract:By unbalant electricity bridge ,this article educed a accurate formulation with which the insulation resistance can be calculated when both the plus insulation resistance and the minus insulation resistance decend in DC system. Moreover it bring forward a design project of small insulation monitoring system named master-slave type.Namely measured insulation resistance of main road with main insulation module,and measured which road’ insulation resistance decended with branched insulation module.And obtained good result in use.
Key Words:Unbalant electricity bridge; Master-slave type; Insulation detecting.
评论(0)
发评论
下载排行榜
