基于RS-485总线的温室环境控制系统研制
消耗积分:5 | 格式:rar | 大小:141 | 2009-06-17
安德森大
分享资料个
作物生长需要一个适宜的环境,在可控环境下,可以不分季节、不分地区地种植所需的作物。控制系统为实现这一目标提供了基础。控制系统设计采用主从模式,基于RS-485 总线协议,设计全数字化传感器和测控输入输出模块;采用COM 组件技术设计应用软件的数据采集、控制算法和控制输出组件。整个系统经过测试和运行,证明满足可控环境调控要求。
关键词:现场总线,分布式系统,COM 组件,可控环境,智能节点
Abstract: The crop growth requires a favorable environment. Crops can be grown at different districts, and different seasons in controlled environments. In order to realize this goal, a new control system based on RS-485 bus is designed in the light of the master/slave mode. The design method of intelligent sensors and I/O modules is given, and the program methodology using COM component techniques is described in developing application software with data collection, control algorithm and control output modules. The system passes testing and the
operation shows designed control system can be true of controlled environments.
Key words: field bus , distributed system, COM component, controlled environment, intelligent node
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
