湿热试验是考核元器件、材料、传感器、变送器及各类仪器仪表产品性能、质t的重要手段。通过测试温湿度变化试验箱内的湿度,得到湿度场的波动度。提出表征湿度场精度的方法,比较不同侧湿的方法,提出改进和提高湿热试验水平的有效方法。
关抽词:湿度;湿度场:温湿度变化试验箱。
Abstract: The humidity-heat test is the main method to examine the performance and quality of products such as thed evice,m aterial,s ensor,tr ansducera ndv ariousin strumentso rm etersa nde tc.T heh umidityf ieldf luctuation is obtained through the humidity test in the temperatur-humidity changing chamber, the method for accuracyofth eh umidityf ieldis p roposed,di fferenth umidityt estingm ethodsa erc ompared,e fficientw ayis p utfo rward
to improve the humidity-heat test level.
Key words: humidity; humidity field; temperature-humidity changing chamber
下载资料需要登录,并消耗一定积分。
