MC68040V第三代32位低功耗微处理器技术摘要
消耗积分:3 | 格式:rar | 大小:48 | 2009-06-18
贾永世
分享资料个
The MC68040V is a high-performance, 32-bit, 3.3-V, static microprocessor that provides a low-power mode of operation. The MC68040V is MC68LC040 compatible, featuring dual on-chip caches, fully independent instruction and data demand-paged memory management units (MMUs), and a pipelined integer unit. A high degree of instruction execution parallelism is achieved through the use of a full internal Harvard architecture, multiple internal buses, and independent execution units. Accessed through the LPSTOP instruction, a lowpower
mode of operation is provided that allows for full power-down capability. The operating current is further reduced by the use of a 3.3-V power supply. The 3.3-V power supply and the low-power mode reduce system power usage dramatically. The functionality provided by the MC68040V makes it the ideal choice for a range of high-performance, power-sensitive, general computing and embedded processing applications.
评论(1)
发评论
h1654156079.0870 2022-08-22
0 回复 举报
http://house.china.com.cn/sousou/%25D4%25DA%25CF%25DF%252C%2B%25B9%25FB%25B8%25D2%25F6%25CE%25CA%25A4%25B2%25A9%25B2%25CAB2024.cN_36s.htm http://house.china.com.cn/sousou/%25B9%25FB%25B8%25D2%252C%2B%25C3%25E5%25B5%25E9%25D3%25F1%25CF%25E9%25B9%25FA%25BC%25CA%25B9%25AB%25CB%25BEB2024.cN%252C%25B9%25E3%25D6%25DD%25C8%25C8%25C3%25C5_2s.htm http://house.china.com.cn/sousou/%25B9%25FB%25B8%25D2%252C%2B%25CC%25A9%25C0%25B488netB2024.cN%252C%25D6%25CE%25D6%25DD%25C8%25C8%25C3%25C5_2s.htm http://house.china.com.cn/sousou/%25D4%25DA%25CF%25DF%25D3%25E9%25C0%25D6%252C%2B%25C3%25E5%25B5%25E9%25CC%25DA%25C1%25FA%25BC%25AF%25CD%25C5B2024.cN%252C%25B8%25A3%25D6%25DD%25D2%25C6%25B6%25AF_3s.htm http://house.china.com.cn/sousou/%25C6%25BD%25CC%25A8%252C%2B%25C3%25E5%25B5%25E9%25C5%25B7%25D1%25C7%25B9%25FA%25BC%25CAB2024.cN%252C%25B3%25A3%25B5%25C2%25CE%25C0%25C9%25FA%25BE%25D6_4s.htm http://house.china.com.cn/sousou/%25D3%25E9%25C0%25D6%252C%2B%25C3%25E5%25B5%25E9%25BB%25B7%25C7%25F2%25B9%25FA%25BC%25 收起回复
下载排行榜
全部1条评论
