The digital potentiometer (DP) allows many of the applications of mechanical trimming potentiometers to be replaced by a solid-state solution. The digital potentiometer has several benefits over a mechanical potentiometer, including compact size, freedom from shock or vibration, and the ability to withstand oil, dust, temperature extremes, and moisture. The interface of a DP allows it to be electronically controlled by a microprocessor or microcontroller so that the user can adjust system parameters quickly and precisely. Also, automatic system initialization and calibration at the point of manufacture can be provided to increase accuracy and timeliness on the production line.
