Trimmed NURBS曲面的展开研究
消耗积分:3 | 格式:rar | 大小:170 | 2009-06-22
王利祥
分享资料个
本文分析复杂曲面中的Trimmed NURBS(裁剪面)曲面表达,讨论曲面曲线的展开算法,在此基础上详细描述Trimmed NURBS曲面展开算法的实现步骤,并通过实例介绍展
开算法在IGES格式的Trimmed NURBS曲面展开的具体应用。本研究主要用于解决三维柱面设计中经常会遇到螺纹的设计、齿轮的设计、螺旋槽的等设计问题。
关键字:裁剪面 NURBS曲面 NURBS曲线 展开 反求
Abstract How to express the trimmed NURBS surface and the unrolling algorthm
on the NURBS surface and curve are discussed in the paper. On the base of the unrolling
algorithm, the unrolling process of the trimmed NURBS surface is analyzed, and the
sample about the unrolling is give. The research can solve the problem of the
three-dimension cylinder design such as screw thread, gear wheel, and screw cap.
Key Words Trimmed NURBS surface NURBS surface NURBS curve Unroll Reverse
评论(0)
发评论
下载排行榜
