This application note is written to accompany the Freescale Semiconductor, Inc reference design forhigh-brightness LED control, and describes an application called LightingDemo.
LightingDemo allows you to control one or more high-brightness LEDs using a PC. It demonstrates how the Freescale Lighting Controller board can be used to control one or more LED slave boards using either of two industy-standard protocols, DMX512/RDM and DALI.
Full source code of the software running on the controller and LED boards is provided.
