心态的开发者工具
消耗积分:1 | 格式:rar | 大小:10337KB | 2014-05-24
戚健鹏
分享资料个
神念科技的软件开发基本资料,淘宝经常要好评后给的东西
MindSet Developer Tools
Readme.txt
The MindSet Development Tools are a set of software tools that make it easy to
create innovative applications that can respond to a user‘s brainwaves and mental state.
If you already have a MindSet, you will be able to take full advantage of it through
our Developer Tools. If you are trying out the developer tools before purchasing a MindSet,
check out the tools and if you have any questions, let us know at support@neurosky.com.
How can I use the MindSet Development Tools?
The MindSet Development Tools contain a number of ways for developers to integrate
brainwave-sensing functionality into existing programs, or to create new ones from
scratch.
fimude
What is included in the MindSet Developer Tools?
There are three APIs: ThinkGear Communications Driver, ThinkGear Connector, and the
MindSet Communications Protocol. One of these different implementations should provide
the most appropriate level of access for your project.
For the newest information, tutorials, and more, please visit: http://developer.neurosky.com
- Ideal for C / C++ / C# / Objective-C
- Windows and OS X shared libraries (《code》.dll《/code》 and 《code》.bundle《/code》)
- Easy-to-use API
The ThinkGear Communications Driver (TGCD) is a native Windows and OS X library that
handles all the “heavy lifting” of interacting with a MindSet, from setting up the
connection to interpreting the data stream received from the MindSet. The API exposed
by TGCD is extremely simple.
TGCD is distributed as a .dll (for Windows) and a .bundle (for OS X), making it
suitable for applications written in C or C derivatives (i.e. C++, C#, or Objective-C)。
ThinkGear Connector
- Ideal for scripting languages like Flash / Python / Ruby
- Windows and OS X executables
- Uses socket APIs
- Headset-less development mode
The ThinkGear Connector (TGC) is a software program - analogous to a socket server -
that runs as a background process on your computer and is responsible for directing
MindSet data from the serial port to an open network socket. It is available on both
Windows and OS X. Any language or framework that contains a socket library should be
able to communicate with it. TGC is an ideal option for developers working in frameworks
like Adobe Flash.
评论(0)
发评论
下载排行榜
