This design is using two MOSFET controllers to regulate the circuit’s high power path. The LM5069-2 (U1) is a high voltage controller with OVLO, UVLO, and current sense capability over an external shunt resistor.OVLO and UVLO are set with external resistor dividers。The OCP is set with a shunt resistor in the high power path. The LM5069-2 is controlling MOSFET Q1。
全部1条评论
