AX88180 Software Programming Guide
消耗积分:1 | 格式:pdf | 大小:531KB | 2014-10-30
wyk193
分享资料个
This document indicates how to implement the AX88180 Gigabit Ethernet controller driver。The AX88180 Gigabit Ethernet controller is a high performance and highly integrated local CPU bus Ethernet controller with embedded 40K bytes SRAM and supports both 16-bit and 32-bit SRAM-Like interfaces for any embedded systems. The AX88180 is a 10/100/1000Mbps Gigabit Ethernet controller that supports both MII and RGMII interfaces and is compliant to IEEE802.3, IEEE802.3u and IEEE802.3z standards。
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
