Wide Input Synchronous Boost Controller with Multiple Phase Capability
消耗积分:2 | 格式:pdf | 大小:2323KB | 2014-11-05
分享资料个
The LM5122 is a multiphase capable synchronous boost controller intended for high-efficiency synchronous boost regulator applications。 The control method is based upon peak current mode control。 Current mode control provides inherent line feed-forward,cycle-by-cycle current limiting and ease of loop compensation。
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
