SE5117,pdf datasheet
消耗积分:2 | 格式:rar | 大小:233 | 2009-07-12
分享资料个
The SE5117 is an efficient linear voltage regulator. It has extra low dropout voltage. At light loads the typical dropout voltage is 5.5mV, and at full load the typical dropout voltage is 650mV. The output voltage accuracy is better than 2%.The SE5117 has low ground current, so it can help prolong battery life. The SE5117 is specially designed for hand-held, battery-powered devices.
评论(0)
发评论
下载排行榜
