79LXX,pdf datasheet
消耗积分:2 | 格式:rar | 大小:233 | 2009-07-12
吴湛
分享资料个
This series of fixed-voltage monolithic integrated-circuit voltage regulators is designed for a wide range of applications. These applications
include on-card regulation for elimination of noise and distribution problems associated with single-point regulation. In addition, they can be
used with power-pass elements to make high-current voltage regulators. Each of these regulators can deliver up to 100 mA of output
current. The internal limiting and termal shutdown features of these regulators make them essentially immune to overload.
When used as a replacement for a Zener diode-resistor combination, an effective improvement in output impedance can be
obtained together with lower-bias current.
评论(0)
发评论
下载排行榜
