介绍了用霍尔传感器和含有单片计算机的智能二次表所构成的转速监测系统,同时,还阐 述了用霍尔传感器和智能转速变送器所构成的DCS 采集通道。着重表述了智能转速表及智能转速变送器的构成、原理及其控制程序框图。 关键词: 转速监测系统;智能监测;霍尔传感器;A/ D 转换器 Abstract : An rotaticnal speed monitor system con2 sisting of Hall sensor and Single Chip Microcomputer is int roduced in this paper , and DCS collecting chan2 nel consisting of Hall sensor and intelligent rotaticnal speed t ransmission is stated too. The const ruction , the principle and the programmed cont rol block of in2 telligent rotational speed meter and intelligent rotat2 icnal speed t ransmission are chiefly discussed. Key Words : rotational speed monitor system ; in2 telligent rotational ; Hall sensor ; A/ D converter
