TPA5051-SRS芯片技术资料
消耗积分:5 | 格式:pdf | 大小:686KB | 2015-01-15
haom
分享资料个
The TPA5051 evaluation module (EVM) consists of a single TPA5051 audio delay device,along with other external components mounted on a printed-circuit board (PCB) that can be used to independently delay two digital audio streams。Each digital audio stream consists of a left and right channel,both of which can be delayed up to 4095 samples (with a 48-kHz sampling rate, that equates to more than 85ms of delay)。
评论(0)
发评论
下载排行榜
