实现I2C总线控制器的VHDL源代码
消耗积分:10 | 格式:rar | 大小:2161 | 2008-05-20
hxjq
分享资料个
I2C总线控制器 altera提供
The I2C Controller was designed for the MC68307 uC, provides a simplified interface to industry-standard I2C protocol. The I2C Controller is available in VHDL and is optimized for the Altera® APEX™, Stratix®, and Cyclone™ device families.
All of the register addresses are defined as constants in the VHDL source files and can be easily customized for customer use. The MBASE address is defined as a generic and can also be easily changed and customized for customer use. In addition, this design outputs the MCF signal on a pin which can be used by the uC as a quick indication that the I2C transfer is complete.
This design uses the I2C SCL signal as a clock. This requires that the SCL signal have clean, fast edges on both the rising and falling edges of this signal. Slow rise and fall times on this signal can show noise effects which can cause improper clocking of registers within the Stratix FPGA. If the loading of the SCL signal in the system is such that the rise and fall times are slow (>20nS), external buffers such as Schmitt Triggers will be required to interface to the FPGA.
评论(5)
发评论
angyangone 2015-06-30
0 回复 举报
感谢楼主!大赞 收起回复
skyliuhao 2015-04-02
0 回复 举报
很好的资料!谢谢楼主 收起回复
全部评论
下载排行榜
全部5条评论
