CD4000, CD4001, CD4002, CD4025
消耗积分:5 | 格式:rar | 大小:122 | 2008-06-01
麻酱
分享资料个
Features
• High-Voltage Types (20V Rating)
• Propagation Delay Time = 60ns (typ.) at CL = 50pF,
VDD = 10V
• Buffered Inputs and Outputs
• Standard Symmetrical Output Characteristics
• 100% Tested for Maximum Quiescent Current at 20V
• 5V, 10V and 15V Parametric Ratings
• Maximum Input Current of 1μA at 18V Over Full Package-
Temperature Range; 100nA at 18V and +25oC
• Noise Margin (Over Full Package Temperature Range):
- 1V at VDD = 5V
- 2V at VDD = 10V
- 2.5V at VDD = 15V
• Meets All Requirements of JEDEC Tentative Standards
No. 13B, “Standard Specifications for Description
of “B” Series CMOS Device’s
Description
CD4000BMS, CD4001BMS, CD4002BMS, and
CD4025BMS NOR gates provide the system designer with
direct implementation of the NOR function and supplement
the existing family of CMOS gates. All inputs and outputs are
buffered.
The CD4000BMS, CD4001BMS, CD4002BMS and the
CD4025BMS is supplied in these 14 lead outline packages:
评论(0)
发评论
下载排行榜
