Main processor instructions that do not require a target address, immediate value, or branch displacement use an R-type coding format. This format has fields for specifying of up to three registers and a shift amount. For instructions that do not use all of these fields, the unused fields are coded with all 0 bits. All R-type instructions use a 000000 opcode. The operation is specified by the function field.
