4050 CMOS六同相缓冲器、转换器
消耗积分:5 | 格式:rar | 大小:64 | 2009-08-08
分享资料个
The CD4049UBC and CD4050BC hex buffers are monolithic
complementary MOS (CMOS) integrated circuits constructed
with N- and P-channel enhancement mode
transistors. These devices feature logic level conversion
using only one supply voltage (VDD). The input signal high
level (VIH) can exceed the VDD supply voltage when these
devices are used for logic level conversions. These
devices are intended for use as hex buffers, CMOS to DTL/
TTL converters, or as CMOS current drivers, and at VDD =
5.0V, they can drive directly two DTL/TTL loads over the
full operating temperature range.
评论(0)
发评论
下载排行榜
