AD8206,pdf,datasheet (Differen
消耗积分:5 | 格式:rar | 大小:377 | 2009-08-25
靓仔峰
分享资料个
The AD8206 is a single-supply difference amplifier for amplifying small differential voltages in the presence of large common-mode voltages. The operating input common-mode voltage range extends from −2 V to +65 V. The typical single-supply voltage is 5 V.
The AD8206 is offered in die and packaged form. The operating temperature range for the die is 25°C higher (up to 150°C) than the packaged part to enable the user to apply the AD8206 in high temperature applications.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
