AD8270,pdf,datasheet (Differen
消耗积分:5 | 格式:rar | 大小:593 | 2009-08-25
分享资料个
The AD8270 is a low distortion, dual-channel amplifier with internal gain setting resistors. With no external components, it can be configured as a high performance difference amplifier with gains of 0.5, 1, or 2. It can also be configured in over 40 single-ended configurations, with gains ranging from −2 to +3.
The AD8270 is the first dual-difference amplifier in the small 4 mm × 4 mm LFCSP. It requires the same board area as a typical single-difference amplifier. The smaller package allows a 2× increase in channel density and a lower cost per channel, all with no compromise in performance.
The AD8270 operates on both single and dual supplies and requires only 2.5 mA maximum supply current for each ampli-fier. It is specified over the industrial temperature range of −40°C to +85°C and is fully RoHS compliant.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
