A703 is a high voltage, adjustable constant current driver for LED applications. Two regulated current ports are designed to provide uniform and pure DC constant current sinks for driving LEDs within a large range VF variations. A703 provides users 2-channel constant current ports to match LEDs with equal current. Users may adjust the output current from 20mA to 150mA through an external resistor, RSET, which gives users flexibility in controlling the light intensity of LEDs. It also could adjust LED brightness from 0% to 100% via enable pin (EN) with Pulse Width Modulation signal. The thermal protection function protects IC from over temperature (150°C). Also, the thermal pad enhances the package power dissipation.
