The OP183 is a single-supply, 5 MHz bandwidth amplifier with slew rates of 10 V/μs. It can operate from voltages as low as 3 V and up to 36 V. This combination of slew rate and bandwidth yields excellent single-supply ac performance, making this amplifier ideally suited for telecom and multimedia audio applications. The OP183 also provides good dc performance with guaranteed 1 mV offset. Noise is a respectable 10 nV/√Hz. Supply current is only 1.2 mA per amplifier. This amplifier is well suited for single-supply applications that require moderate bandwidth even when used in high gain configurations. This makes it useful in filters and instrumenta-tion. The output drive capability and very wide full-power bandwidth of the OP183 make it a good choice for multimedia headphone drivers or microphone input amplifiers. The OP183 is available in a SO-8 surface-mount package. It is specified over the extended industrial (−40°C to +85°C) temperature range.
