AD7782,pdf datasheet (Pin Conf
消耗积分:2 | 格式:rar | 大小:573 | 2009-09-10
hxjq
分享资料个
The AD7782 is a complete analog front end for low-frequency
measurement applications. The 24-bit sigma-delta ADC contains
two fully differential analog input channels that can be configured
with a gain of 1 or 16 allowing full-scale input signal ranges
of ±2.56 V or ± 160 mV from a +2.5 V differential reference
input.
The AD7782 has an extremely simple, read-only digital interface
which can be operated in master mode or slave mode. There are
no on-chip registers to be programmed. The input signal range
and input channel selection are configured using two external pins.
评论(0)
发评论
下载排行榜
