The AD7783 is a complete analog front end for low frequency
measurement applications. The 24-bit sigma-delta ADC contains
one fully differential input channel that can be configured
with a gain of 1 or 16 allowing full-scale input signal ranges of
±2.56 V or ±160 mV from a +2.5 V differential reference input.
It also contains two 200 mA integrated current sources.
The AD7783 has an extremely simple, read-only digital interface
that can be operated in master mode or slave mode.
There are no on-chip registers to be programmed. The input
signal range and current source selection are configured using
two external pins.
