AD1866,pdf datasheet (Dual 16-
消耗积分:5 | 格式:rar | 大小:547 | 2009-09-12
370217
分享资料个
The AD1866 operates on +5 V power supplies. The digital
supply, VL, can be separated from the analog supply, VS, for reduced
digital feedthrough. Separate analog and digital ground
pins are also provided. In systems employing a single +5 volt
power supply, VL and VS should be connected together. In battery
operated systems, operation will continue even with reduced
supply voltage. Typically, the AD1866 dissipates 50 mW.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
