ADV7324,pdf datasheet (14-Bit
消耗积分:3 | 格式:rar | 大小:507 | 2009-09-14
刘艳
分享资料个
The ADV®7324 is a high speed, digital-to-analog encoder on a
single monolithic chip. It includes six high speed NSV video
DACs with TTL-compatible inputs. It has separate 8-/10-,
16-/20-, and 24-/30-bit input ports that accept data in high
definition (HD) and/or standard definition (SD) video format.
For all standards, external horizontal, vertical, and blanking
signals, or EAV/SAV timing codes, control the insertion of
appropriate synchronization signals into the digital data stream
and, therefore, the output signal.
评论(0)
发评论
下载排行榜
