AD8123,pdf datasheet (Adjustab
消耗积分:3 | 格式:rar | 大小:727 | 2009-09-15
tr12345
分享资料个
The AD8123 is a triple, high speed, differential receiver and equalizer that compensates for the transmission losses of UTP and coaxial cables up to 300 meters in length. Various gain stages are summed together to best approximate the inverse frequency response of the cable. Logic circuitry inside the AD8123 controls the gain functions of the individual stages so that the lowest noise can be achieved at short-to-medium cable lengths. This technique optimizes its performance for low noise, short-to-medium range applications, while at the same time provides the high gain bandwidth required for long cable equalization (up to 300 meters). Each channel features a high impedance differential input that is ideal for interfacing directly with the cable.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
