AD8152,pdf datasheet (Asynchro
消耗积分:3 | 格式:rar | 大小:548 | 2009-09-15
分享资料个
AD8152 is a member of the Xstream line of products and is a
breakthrough in digital switching, offering a large switch array
(34 × 34) on very little power, typically 2.0 W. Additionally, it
operates at data rates up to 3.2 Gbps per port, making it suitable
for Sonet/SDH OC-48 with Forward Error Correction (FEC).
The AD8152’s useful supply voltage range allows the user to
operate at LVPECL/CML data levels down to 2.5 V. The control
interface is LVTTL or LVCMOS compatible on 2.5 V to 3.3 V.
The AD8152’s fully differential signal path reduces jitter and
crosstalk while allowing the use of smaller single-ended voltage
swings. It is offered in a 256-ball SBGA package that operates
over the industrial temperature range of 0°C to 85°C.
评论(0)
发评论
下载排行榜
