ADF4360-8,pdf datasheet (Integ
消耗积分:5 | 格式:rar | 大小:551 | 2009-09-16
敷衍作笑谈
分享资料个
The ADF4360-8 is an integrated integer-N synthesizer and voltage-controlled oscillator (VCO). The ADF4360-8 center frequency is set by external inductors. This allows a frequency range of between 65 MHz to 400 MHz.
Control of all the on-chip registers is through a simple 3-wire interface. The device operates with a power supply ranging from 3.0 V to 3.6 V and can be powered down when not in use.
评论(0)
发评论
下载排行榜
