Slew Rate of Op Amp Circuits
消耗积分:3 | 格式:rar | 大小:433 | 2009-09-26
Petc
分享资料个
Slew Rate of Op Amp Circuits:The slew rate (SR) is defined as the maximum rate of change of the output of an op amp circuit. The SR in general describes the degradation effect on the high frequency response of the active amplifier (one with an op amp) near or at the rated maximum output voltage swing. This effect is generally due to the compensating capacitor and not to the transistor circuits internal to the op amp. In short, the SR effect is due to the maximum supplied current available for charging up the compensating capacitor.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
