LM2696,pdf datasheet (Constant
消耗积分:5 | 格式:rar | 大小:555 | 2009-09-28
笑过就走
分享资料个
The LM2696 is a pulse width modulation (PWM) buck regulator
capable of delivering up to 3A into a load. The control
loop utilizes a constant on-time control scheme with input
voltage feed forward. This provides a topology that has excellent
transient response without the need for compensation.
The input voltage feed forward ensures that a constant
switching frequency is maintained across the entire VIN range.
The LM2696 is capable of switching frequencies in the range
of 100 kHz to 500 kHz. Combined with an integrated 130
mΩ high side NMOS switch the LM2696 can utilize small
sized external components and provide high efficiency. An
internal soft-start and power-good flag are also provided to
allow for simple sequencing between multiple regulators.
The LM2696 is available with an adjustable output in an exposed
pad TSSOP-16 package.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
