LM2796,pdf datasheet (Dual-Dis
消耗积分:3 | 格式:rar | 大小:550 | 2009-09-30
绝代双骄
分享资料个
The LM2796 is a charge-pump based white-LED driver that
is ideal for mobile phone display backlighting. It can drive up
to 7 LEDs in parallel with up to 20mA through each LED.
Regulated internal current sources deliver excellent current
and brightness matching in all LEDs. The LED-driver current
sources are split into two independently controlled groups.
The primary group (4 LEDs) can be used to backlight the
main phone display. The second group (3 LEDs) can be
used to backlight a secondary display or to provide other
lighting features (keypad LEDs, for example). Brightness of
the two groups can be adjusted independently with pulsewidth
modulated (PWM) digital signals.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
