LM2791,pdf datasheet (Current
消耗积分:3 | 格式:rar | 大小:554 | 2009-09-30
417804
分享资料个
The LM2791 is a CMOS charge-pump voltage doubler and
regulator that provides two regulated current sources. The
LM2791 is designed to drive two white (or blue) LEDs with
matched currents (within ± 0.3%) to produce balanced light
sources for display backlights. They accept an input voltage
range from 3V to 5.8V and maintain a constant current
determined by an external set resistor.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
