LM2937-2.5,pdf datasheet (400m
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-05
分享资料个
The LM2937-2.5 and LM2937-3.3 are positive voltage regulators
capable of supplying up to 500 mA of load current.
Both regulators are ideal for converting a common 5V logic
supply, or higher input supply voltage, to the lower 2.5V and
3.3V supplies to power VLSI ASIC’s and microcontrollers.
Special circuitry has been incorporated to minimize the quiescent
current to typically only 10 mA with a full 500 mA load
current when the input to output voltage differential is greater
than 5V.
评论(0)
发评论
下载排行榜
